Hello. I'm new to the forum and to programming aswell. I'm trying to learn how to make an app so I started with a tutorial online, but I'm having a problem. Here's a link of the tutorial https://www.raywenderlich.com/56109/make-first-android-app-part-2
On the section "Accessing Views From Within Java" when I add "android:text= @String/hello_world"" I get an error. On the bottom it says I should be using a @String but when I do the preview window displays the @String/" aswell. What's that about?
Second, I can't rename the string after changing hello_world to something else. Why is the tutorial even saying I should rename it? What will that do?
Lastly, in MainActivity.java above onCreate I have to insert a line of code. The tutorial doesn't explain why I need to do that. Where should the line go, the code is
setContentView(R.layout.activity_main);
wherever I insert the code and press Alt+Enter I mess up the whole thing...
Sorry that these questions are annoying and basic, I just really want to learn to make apps and I'm trying to figure things out alone.
Thanks.
P.S. one more thing, in "Buttons and Listeners" there is a part saying:
"Then there’s text, for which you need to add a line in strings.xml such as the following:
<string name="button">Update The TextView</string>"
when I do that I get an error in strings.xml
Thanks.
