Problem with Jorte Calendar
mna8847
Quick question from a new user:
I downloaded Jorte on the advice of a Verizon rep (who seemed genuinely knowledgeable). She also recommended this site AND got my Palm contacts downloaded into my new Droid X, so I figured she knew her stuff. (Thanks, Sarah!)
When I try to enter the start and end times for a new event, the outline box navigates from left to right as I select numbers from the keyboard, but no numbers show up in the boxes.
I have to go back to the main event screen to see what I've entered.
I've tried changing the color sceme via "Style" with no luck.
Help :)
Thanks!
Monica
Help :)
Thanks!
Monica
Is it hte built in Droid X keeyboard you are trying to use to enter the times or the one that pops up (built into Jorte) that you are trying to use.
I just tried and when I click on the time a new box shows up with a number pad and that allows me to enter the time.
Thanks for answering.
I'm using the keyboard which pops up when I hit the "start time" or "end time" field.
I was expecting to be able to see the number I entered once I got to the next/blank number field.
Tangent Alert: Stay safe where you are.
If you are in the military, htat goes double from one soldier to another.
Monica
