Problem with nimbuzz on 3g network
ariel1w
Hello to all,
I have nimbuzz on my milestone 2.1
I am trying to make VOIP calls on my skype account through nibuzz.
When using wifi it works great.
When using 3g I have a weird prob.
I can recieve calls fine but I when I call someone I can't hear the person answering and he/she can't hear me. It won't work even with echo sound test.
Does anyone have any idea why this would happen.
I tried uninstalling and re installing and all that so...
Thank you
Hello to all,
Thank you
Try using an alternative to nimbuzz - fring.
Alternatively for voip alone you have a choice of sipdroid, sipagent, or 3cx.
Your lucky you got Nimbuzz voip working on ANY network... there are tons of people with issues on their forums and they seem clueless as what the the problem is,.
You attempt to make a call, the recieving party rings but no audio..
Nimbuzz is a nice polished looking app, if they fixed voip it would be great.
Fring works really good with voip, I connect via a buddies astrix box and use it like a regular cell phone.. Just make sure if your on longer calls to disable wifi sleep if your on wifi.
