Hi,
I have a Samsung Galaxy POP GT-S5570. Due to its limited internal memory, I've been trying for the last 2 days to partition the sd card and use link2sd on the 2nd partition. Once I do this, I'm unable to get my Windows 7 PC to recognize the sd card... Here's the full detail of what I did. I'm a novice, and the first time I went through this process a couple of days back, I screwed up my phone royally, and had to visit the Samsung service center to get a factory reset done. So, yeah, my phone is in virginal mode as I start these steps.
Ultimately, I absolutely have to be able to transfer files from my PC to sd card, and have it working on phone. How do I fix this issue?
- Rooted my phone as per instructions (I had no problems here)
- Installed the CWM recovery module as per the instructions. CWM also appears to be running fine, I seem to have no problems here.
- Used CWM to partition the sd card. Did it successfully.
- Installed Link2SD. It seems to recognize the 2nd partition.
- At this point, if I connect my phone to my Windows 7 PC, even after enabling USB mass storage mode on the phone, it does not show up as a drive on my PC.
- I unmounted the SD card, loaded it into my card reader, and loaded into the PC. It recognized the card, but said the card needed to be formatted before use.
- Not knowing what else to do, I tried using MiniTools to format the SD card on the PC. No effect, windows explorer still said the drive needed to be formatted. So I used windows explorer format option to do a full format on the sd card.
- After this, the PC recognized the card, but when I loaded it back in the phone, the phone could not detect the 2nd partition (probably wiped out??). I used CWM to re-partition the drive. Now Link2SD recognized the partition, but it has also brought me back to Steps 5/6. My comp will not recognize the card.
