Help problem with sd card
Pain0005
hello,
i don't know what it happened but my phone doesn't mount automatically the sd card during boot, every application says "sd card doesn't exist".
the sd isn't broken and if i mount it manually with terminal emulator, with filebrowser can acces only the 1st level of sd.
my phone is useless in this way, i can use it only for call -_-"
what have i to do to fix it? please help!
Hello Pain0005. Welcome to Android Forums. You might try physically removing the sd card and then reinserting it. Once replaced, go into your settings and there should be an option to mount the sd card. Once mounted it should be fine unless there is a deeper problem. I hope this helps. Thanks for joining the AF community.
