Help Problem with SEUS
Does anyone else have a problem with SEUS.
When i want to turn my rooted X10 to standerd 2.1 i can't do it with SEUS anymore.
It says that i already have the latest firmwire.
How can i now make my X10 standerd again???
If all you've done is root your X10 and you haven't loaded any custom ROMs, themes, or firmware to your phone, you don't have to use SEUS. You just need to unroot your phone and you're back to the way it was before you rooted.
Otherwise, you can use PC Companion. Tell it to search for updates and when it tells you, you are up to date, it will give you the option to cancel or repair. Select repair and follow the instructions and you'll be back to the stock SE ROM. Hope this helps!
I think there is a way to do this with SEUS too but I can't remember the procedure at the moment (I think it's the same as updating and telling it to install anyway after it says you're up to date).
