This will probably be a pretty "moronic question" so please forgive my ignorance!
I'm a hobbyist web developer but decided to delve into the world of Android Apps thanks to my incredible..
Anyway.. To the point..
I decided to start with a soundboard to get a handle on how it works.. I've hit up many forums including the
SoundPool | Android Developers
Which was a great help!
My only issue right now is that I can't seem to get the sounds to stop overlapping one another.. Once you push a button the sound starts but if you push another button the previous button keeps playing; overlapping one another. The solution I'm guessing is easy for an experienced developer so any help would be appreciated as I just started learning this language two days ago... I Purchased a ton of books though, and can't seem to find the answer even though I know it's there.. "Just don't think I know where to look" I'm using eclipse and soundpool...
THANKS IN ADVANCE!!
Anyway.. To the point..I decided to start with a soundboard to get a handle on how it works.. I've hit up many forums including the
THANKS IN ADVANCE!!
