Hi all,
So I'm having a little issue syncing music onto my Atrix HD using Windows Media Player 11. I recently got a 32GB SDHC memory card and decided to load it up with music to make my iPod unnecessary to carry around with me.
I set up the sync and everything. I had two different sections for my Atrix HD, one specifically for Internal Memory and one for the SD Card. Sometime during the sync, I got a phone call which halted the process entirely. From then on, my internal memory and SD card memory became fused.
I've managed to bypass it by taking out my SD hard and quickly putting it back in, but I don't feel like that's a good thing to do.
I have also tried these things:
Re-installing Motorola Device Manager
Restarting my computer
Unplugging and plugging in my device
Deleting WMPInfo.xml (which worked for a second, and then WMP froze. Now nothing happens when I delete the file)
Unmounting and mounting the SD card
Restarting my device
Ending sync partnership with the device
My computer detects both of the memory drive separate, so I can manually add music files, but that seems to cause organization problems with the media player on my phone.
Windows Media Player detects my phone without the SD Card as "Nick's Phone - SD Card" and with an SD Card "Nick's Phone - SD Card - Internal Memory," however the memory amounts for both are exactly the same, and are my device's internal memory, which is like 3.5GB, opposed to the 29.7GB that should solely exist on my SD Card.
I'll appreciate any help you all can give me!
Thanks.
EDIT: Strangest thing, when I unmount the SD Card and then mount it and refresh my Windows Media Player devices, my phone becomes detected as "Nick's Phone - SD Card - SD Card." The memory amount displayed is correct, and it syncs to the SD Card.
Thanks.
