Problem with Weatherbug Elite
UrsusVIIILXXXVII
I'm using version 2.5.288 and I can no longer see a map with the radar. Everything else works fine but I can only see a white grid instead of a map of any kind. I've uninstalled/reinstalled a few times with no results. Has anyone else had this problem?
Is there any other app that's as comprehensive as weatherbug elite in the U.S.?
I am having the same problem .. tried everything but to no avail ... installed the free version and worx fine ... anyone have any ideas why this is happening ... thanx
I experienced this same problem with the doppler radar widget, on my Motorola Backflip. Sometimes I removed the widgets from the home screen and placed them back on the home screen again to fix the problem. I have an Atrix now, and haven't had the problem.
I have read some others posts on different sites and it seems that its due to an update .. not really sure
is there any other weather app with decent radar?
I now have version 2.5.358 and no longer have issues. Looks like the problem has been fixed.
I actually forgot I had made the original post here. I had been using Mycast weather and it was...adequate. All I really wanted was animated radar but now since the newer version of weather bug is working, I deleted mycast.
I have the most recent version and do not have a problem with the radar. However I have a problem in that the app will not update my location. Yes I have all the correct settings selected, I think, at least I have not changed anything since I installed many months ago. I can turn off and back on the enable my location selection and it will update but that is the only time.
Any ideas? This sucks!!
Make sure you have the update rate set right.
