Problems after apps 2 SD card
Cybert
Hallo, i have experienced big problems after using Apps 2 SD Card application which is intended to store parts of apps on SD card. It seems it did moved also apps which shlould not be moved, so most of them needed be reinstalled, which I did. But still there are some apps which even after reinstall behaves strange - like did not store its settings after soft reset, or logging off when phone goes to sleep, or behaves like each time like start for the first time. I have been thinking about doing factory reset or SD card formating. Do you think it might help, or is there another solution? Apps which are installed freshley works well. only those reinstalled cause the problems.
