Problems of my Pixel XL so far...
Just noticed that this is my second post in Android Forums. The first one was posted when I was using HTC Desire back in 2011, time flies doesn't it? ;)
So I was quite lucky that I received my Pixel XL on 2x Oct and have now been using it for about 3 weeks. It's indeed a nifty flagship device from Google that comes with sleek aluminium build, nice camera and the tasty Android 7.1 Nougat. Where most functions of the device work perfect, I find the following issues -
1. As many of you have mentioned in other posts, the Pixel devices load gifs and videos very slow sometimes, especially in the Facebook app.
2. It has happened many times that the phone failed to play videos and music on Spotify, YouTube, and other SNS other than Facebook. A re-boot can solve the problem, but it just happens again after a random period of time.
3. It fails to make and receive VoIP calls - this really happens a lot. I've seen it happened on Whatsapp, Facebook Messenger, Skype, and WeChat. Again, after re-boot it should work slightly better, but I think there should be an official solution to this. Normal phone call doesn't have such problem, though.
4. It disconnects from Wifi on a pretty regular basis.
5. I received my customised Live Case this afternoon. After putting it on, the device has frozen twice. Not so sure if it has anything to do with the NFC, but it never happened before the case.
The above sums up my situation for now. Please tell me if you are also facing the same problems!
Welcome back :)
The facebook app has been the source of issues for several people - not just on the Pixel, but also on other devices. Very battery hungry for some people. I don't use that app, so I don't have any personal experience to share, but the issue you shared may be just the app misbehaving.
The other issues however are unexpected. I use my Pixel XL for music and video streaming quite often, and it works very reliably (Youtube/Google Play Music). Same thing for VoIP calls (Whatsapp, Skype, Hangouts).
The one common factor for most of the issues you reported is your connectivity - are you experiencing this issue when you are using WiFi and/or Mobile data?
When you have this issue the next time, run a speedtest on your phone and see what speeds you have for upload/download
Also, are you on the stock ROM, unrooted?
Welcome back :)
I'm on the stock ROM, unrooted. :P
And I agree that there's connectivity issue with my Pixel XL - the Wifi connection frequently restarts - shall I order a replacement?
I'm on the stock ROM, unrooted. :p
Try connecting to a different WiFi network (maybe at a friend's home, or at an office) - see if that helps. If it doesn't, yeah, contact Google Support
