Hi,
I recently purchased 2 Tplink 500mbps wifi powerline adapters as my house has internal brick walls and the wifi signal is awful downstairs. The problem is that both android devices in the house, S3 mini and S4 mini NEVER seem to be connected to the strongest signal unless the wifi is turned off then back on again.
My wifi signal always seems very weak until i switch it off and on, forcing it to go searching for a signal and choosing the strongest. There are 4 "other" wifi devices in the house and 2 laptops that dont seem to have this problem and automatically connect to the AP with the best signal.
The powerline adapters just replicate all the routers AP credentials and as far as im aware all devices should connect to the best signal. It looks like im always on the limits of 1 AP and the android devices dont want to drop this connection .
Anyone got any ideas on how to solve this?
Thanks,
Mark
Thanks,
Mark
