Root problems with fission Rom Manager
phant14
I am currently running fission 2.4.3 I went to fission rom manager and went to download fission 2.6.1 black edition so I can load it onto my droid 2. It began downloading it got to like 55% then stop downloading and said Error no more room left on the device. My sd card is 8 gb. How do i solve this issue?
You could also delete the entire Fission ROM Manager folder on your SD Card and start clean with all your downloads. But like Super mentioned, make sure you've got a cleaned up SD card.
I too am having problems with fission and the rom manager, i have downloaded the fission rom from the fission rom manager and i put it in the install queue and i hit install but nothing happens... so then i decide to install it from bootstrapper and it says its installed but i have the same boot animation and i go into a bootloop, what do i do to get the rom manager and the rom to work?
Through bootstrap get yourself back to a stable back-up, preferably stock. Go To Settings -> Apps -> Clear Cache and Data from Fission ROM Manager. Then navigate to the Fission ROM folder on your SD card and delete it.
Give yourself a freshstart just in case the downloads were getting corrupted. Also, whenever possible, use a WIFI connection when you're downloading those big files.
ive tried that when i last did it, do uk how to fix the thing where i cant install directly from fission rom manager?
i tried wiping the data and cache and re downloading and it didnt work, also it wont let me install from the fission rom manager, whenever i click install nuthing happens..
Sounds like you might need a clean slate. SBF yourself back to factory settings, let Google restore your apps and settings, go in and fully customize the settings and screens and all. Root it then Make yourself a back-up using this stock-stable set-up. then try installing the Fission ROM manager and re dowloading and putting into the queque then inslatting.
Sorry I couldn't be of more help.
