Help Problems with fix for kitkat 4.4.2 on Chinese Tablet
vernhall
I've tried 'all' the fix apps but, while each says the 'fix' was successful, none have worked to allow me to write to the extsd card. I've also went in to the 'platform.xml' file, where the 'patch' is placed by the 'fix' apps, and the 'fix' has been written there. Have also changed the mount on all from 'r' to 'rw'.
The tablet I'm using is an Irulu X10 that is rooted. This has been verified by all but 1 of the 'root checkers' I've tried. And I do have SuperUser status via SuperSU with all rooted programs appearing to work properly.
However, when I use ES File Manager to attempt to add a new folder to the extsd card I get the following error:
Error: Your system forbids ES from writing on externalSD card(check https://code.google.com/p/android/issues/detail?id=67570), so ES can only write on it after rooted.
I'm at my wits end on this. Have tried everything I have found from searching the net with no success. What am I missing? Could the tablet be only 'partially' rooted? Used RootGenius to root it and the installation went thru with no problems and their version of SuperUser (KingUser) was installed which, supposedly, indicates it was a good root. Where do I go from here?
