Hello
sorry for my English first,
I have a htc magic with the 1.6 original of vodafonre, but I think I have bricked because I do not recognize any sd card.
I've done the command fastboot.exe oem enableqxdm 0, and returns me:
(bootloader) [ERR] Command error !!!
so it does not work the sd card rective
I also run fastboot.exe oem boot and I returned it:
C:\Archivos de programa\Android\android-sdk\platform-tools>fastboot.exe oem boot
(bootloader) setup_tag addr=0xA0000100 cmdline add=0x880705C0
(bootloader) TAG:Ramdisk OK
(bootloader) TAG:smi ok, size = 64
(bootloader) TAG:hwid 0x1
(bootloader) TAG:skuid 0x1E300
(bootloader) TAG:hero panel = 0x0
(bootloader) TAG:engineerid = 0x2
(bootloader) Device CID is not super CID
(bootloader) CID is VODAP304
(bootloader) setting.cid::VODAP304
(bootloader) serial number: HT963KF11277
(bootloader) commandline from head: no_console_suspend=1 console=null
(bootloader) command line length =344
(bootloader) active commandline: board_sapphire.disable_uart3=1 board_sap
(bootloader) phire.usb_h2w_sw=1 board_sapphire.disable_sdcard=1 smisize=6
(bootloader) 4 androidboot.baseband=2.22.19.26I androidboot.cid=VODAP304
(bootloader) androidboot.carrier=VODA-Spain androidboot.keycaps=qwerty a
(bootloader) ndroidboot.mode=normal androidboot.serialno=HT963KF11277 and
(bootloader) roidboot.bootloader=1.33.0007 no_console_suspend=1 console=n
(bootloader) ull
(bootloader) PARTITIOM_NUM_MAX =6 Valid partition num=6
FAILED (status read failed (Too many links))
finished. total time: 6.594s
Please I need help, I can not use the sd card
Thank you very much
(bootloader) ull
Thank you very much
