Help Problems with my Note 5
alec92
Member
Hi guys,
I rooted + installed Xposed on my Note 5 a couple months back and it's been working fine until today when a couple calls dropped out randomly. It then gave me an error saying "Unfortunately the process com.android.phone has stopped" and it also said something like "Messages has stopped". I lost reception, and when I tried to open my Messages app it crashed straight away.
I restarted about 10 times, and did a factory reset through recovery mode (twice) and still had the same issue.
I then tried to install Dr Ketan ROM using the instructions in this post. I followed the instructions perfectly but I keep getting a "KERNEL IS NOT SEANDROID ENFORCING" error and it gets stuck at that screen and won't boot. I've left it for up to 30mins and still no luck. I've done a factory reset a few times and tried installing Dr Ketan ROM twice now. I'm using the 920i kernel so shouldn't be an issue.
I don't really care about root and custom ROM (I'd actually prefer to stay away) so I might try flash a stock ROM. Any other thoughts/advice/tips? Anyone know why I had the first issue, or why I'm having the issue not being able to boot?
I'm on my phone 24/7 for work so need it fixed ASAP!!
Cheers
