Problems with PvZ 2
Zosimus
During the update process for PvZ 2 my Motorola XT914 Razr D1 ran out of memory and the update failed. Since that time the game has been using almost double its normal memory allotment. I want to purge the half-installed update and free the memory it is consuming. Any ideas?
Using a file manager, go to sdcard/android/obb and there should be a folder for plants vs zombies. If there's an extra file in there you should be able to delete it.
