problems with roehsoft ram expander and custom roms
well, they are two major problems not only one
1- I have samsumg galaxy s (i9000) , and you know that the ram is really low , so I swaped the phone to have extra ram (I needed this because the device closes when I surf the internet using dolphin browser which eats up too much ram ) , to do swap I had to install a custom rom on the device , also I use roehsoft ram expander to expand the ram on the expense of my external sd card.
the problem is that every time I reboot the phone , I had to open roehsoft ram expander and create the swap file again and again as i find a low value of ram smaller than the value I already adjusted, I don't understand why this happens maybe I'm not able to use roehsoft ram expander?
2- using custom rom made some apps don't work properly which in turn made the device lag and made it very very slow and nonresponsive after trying to use some apps such as whatapp and viber , I need these custom roms for the swap file so I can't return to original roms :(((
I hope you can understand my problems and help me fing a solution
