Problems with Visual Voice
  • Start date Start date
A
Android Question
Guest
The visual voice does not work, it inform "stopped process"
Best option is to go to Settings - Applications - select the All tab, then scroll down until you find Visual Voice Mail. Select VVM, and when the information tab opens it, make sure you delete data and cache by selecting the appropriate buttons. Reboot your phone and that should help it.
