Hello
I just updated my X10 mini to android 2.1 (u1) and i cant connect to the internet at work anymore.
It says: Getting ip adress, then it says connection failed.
It seems that im the only one haveing problems here at work, some other folks here got the same phone and they can connect.
When running 1.6 it worked great.
It`s WEP secured and i have checked that the password is right.
Have tried wifi fixer, but didnt help.
Also tried reinstall/repair the software on the phone.
I can connect to the internet useing the wireless at home. (Not wep secured though)
Any suggestions?
Thanks
Espen
Any suggestions?
Thanks
Espen
