Jayywizz
Started stock 4.4.4.I rooted with king root. Have twrp. Went to terminal in twrp typed : reboot disemmcwp
So I have r/w. Boot twrp wiped the 4 things I was supposed to. Reboot recovery. Flashed butternoob v2. Everything fine but mic and headset wouldn't work with calls every now and then. Flashed butterkat. Wifi didn't work. Then back to all stock. Tried butterkat with stock 4.4.4. Wifi not working still even after trying to use flashify to flash my backup kernel. Any fixes for any of this? All I really want. Is a kernel I can overclock on. Btw overclock and everything worked fine on the kernel just no wifi.I can change kernel back to stock all I want, it doesn't do anything. I have to flash stock Rom for it to fix kernel.
