Android Addict
This is where we will post if we have any ideas for a project that we can start. Remember that no idea is a bad one so post as many as you can think of.
I have found about 5 different mods we can use and I am still looking. Mostly XML editingYeah I can edit that. What do you have in mind? I can put the Spirit for now but the problem with working on other phones is that we need a tester that owns the phone because a lot of people can get stuck in a bootloop if we just throw the untested mod at them
Edit: Good suggestion man
1-make sure u have ur data disabled or in airplane mode
2-go to root explorer
3-change r/o to r/w(at the top of the screen.
4-Navigate to Data/System
5-Inside Data/System you will find a folder named "Throttle"
6-Long press Throttle folder and select permessions
7-Change permissions to Owner: read and execute only, everything else should be unchecked.
8-when ur done with that press ok and go back to the Throttle folder
9-there should be two files in it(sumtimes only 1,and thats ok too)
10-delete the files from the throttle folder you are in
11-Back out of Data/System to the first menu you were in when you started root explorer
12-change r/w back to r/o
13-exit root explorer and reboot
14-once your phone is up and running,turn your data back on,then your good to go.
you should notice a increase on a speed test. if there is no change you can go back in throttle folder,if those 2 files are back then you prolly missed a step,just go and do the process over again.
Make sure to give the boost guy credit
