ericwilborn
When it came to protecting my Galaxy Nexus, I looked no further than Seidio. They protected my Bionic so well that I couldn't pass them up. While the construction of this case was slightly different from that of my first from Seidio, the protection wasn't compromised at all. This case has definitely saved my phone more than once.
The simpler design is slimmer and only consists of two layers: a silicone skin wrapping the phone with drop/shock protection and a strong plastic skeleton holding it in place. All ports, speakers, microphones, and the camera are open and available at all times with this case. The grooves in the silicone enhance the feel and grip on the device so much that I like the phone better with this case. The buttons are also more responsive thanks to the silicone layer. While I choose not to use a screen protector on the device, the silicone layer makes it easy to apply one and not worry that it gets plied up at the edges.
Seidio's Active Combo is a combo because it also includes a sturdy clip. With the ability to adjust to 7 different angles, the clip can be worn by anybody nearly anywhere on a bag or their person. The clip's face-in design paired with a felt lining completes the protective experience.
