I have a Samsung Stratosphere 2 with an extended battery through Verizon Wireless. I am finding it IMPOSSIBLE to find any cases to fit this phone! I need help! I don't know where else to look!
Extended life batteries tend to be a larger size than stock and require a different back plate.
Seeing is there is no standard sizing for aftermarket accessories, your only recourse is to try the website of the manufacturer that made your extended life battery.
I hope this answer has assisted you with your issue! Please note that if you have any questions you can easily resubmit another question using the same
