Help Proxy settings for Wi-fi Connection
logangr
Hi all,
i am trying to connecto through my jobs wifi which has proxy settings. Is there a way to add those settings so as to be able to update apps and connect to the internet?
Thanks a lot
No facility in Android for underlying proxy (yes bizarre - not even on 2.1 as far as I have read!) - apps in the marketplace to get the browser to use a proxy - but I'm not sure they support user authentication credentials.
Also the proxy app(s) only support the browser - so other web apps (you tube etc) will still not work.
You can add the proxy details (in Galaxy S): But if there is user authentication required then its a problem!
To add the proxy settings:
1. In the wifi settings page click menu button
2. Click Advanced
3. Enter the proxy name / ip and the Port number
I have added proxy details via the settings, wi-fi, advanced.
The problem is, that uses a proxy for every wi-fi connection it makes. Fro example, the proxy is needed for my work wireless, but when I go home, I dont need the proxy so im being forced to delete it whilst at home and re-enter back at work. Other software out there lets you define a proxy per seperate wireless settings.
Hi, I am using Galaxy S,I have also added my workplace's own proxy name and post number to wi-fi connection, but I can not connect to internet from my work! However,there is no problem from home.Can everybody help me,pls:(
2. Click Advanced
Hi.. What is the solution to this problem ??
Guys the proxy support is there but i cant save after entering expetions. i can browse and browse but streaming is a problem. and it will be solved once i can enter and save exceptions. any ideas?
ok i'm sorted, thanks. whatever i can do on my work's network works perfectly on my wifi at home and through my phone!!!!! im over the moon!!!!!!!!!!!!!!!!!!!!!!!!! :D
