Hey Guys,
I think I bricked the device, all help would be appreciated. I have the Geniatech atv310B (M3). I was flashing with the XDA developers gotham build. I copied all of the files to the SD card and placed it into my receiver. Then, I hit the reset button and plugged it into the power. However, My hand slipped and I accidentally let go of the reset button. Thinking that I had not not started the flash process correctly, I took it off power to do it again(I SHOULD NOT HAVE DONE THAT). Now, it won't turn on. It has not responded to some of the solutions of using a bootable SD card or placing certain files on the SD card and rebooting it while holding the reset button.
Does anyone have any possible solutions?
Thank you.
Thank you.
