I have galaxy mini which was network locked to H3G (Hutchison 3G) Ireland. I unlocked it with the help of tutorial (thanks to XDA developers and members). It worked with every other network sim and not the one i am on, i tried making calls and texts through other networks (not the one it was locked on) and it worked fine.i then flashed cwm 10.1 nightly custom rom and everything was going smooth. The blues start when i flashed other stock rom with different modem (baseband), I did that because i read in forums that flashing other modems (basebands) may help resolve the issue of that particular network that was not working but it end up totally negative, i tried almost every network sim available in my country and none of them worked, when i make a call it said "network not available" and shows empty network bar. i then found stock firmware from sammobile.com of my particular provider and model (with the same stock baseband) and flashed it via Odin. No luck, i then again tried different network sims and none of them works all they say "network not available" although i am now on the same stock baseband. I checked my imei number by dialing *#06# and its correct (matches with the box), any chances of corrupt "efs folder?"
This is my sad story, currently i am on cm 10.1 nightly (up to date) with the default stock baseband. No network/sim works. My mini is more like a media player now. Any help from the developers, moderators and members will be deeply appreciated. Below are some pictures attached please have a look at them.
