alostpacket
Over Macho Grande?
Hi gang,
So I have to admit my overclocking skills are weak-sauce and it's been a long while. So I wanted to ask a few quick questions about OC'ing.
First my current setup
Processor: Intel Core i7 920 2.66Ghz --- OC ---> 3.6Ghz
Mobo: EVGA X58 SLI (Model: 132-BL-E758 Version: Tylersburg)
Cpu Socket: Socket 1366 LGA
Current Memory: 3x 2GB (6GB total) Crucial DDR3 1333Mhz
Memory Slots: 6 (24GB max I think)
The questions:
1) I have this system OC'd. And because of the way Intel boards/CPUs OC via the multiplier, I *THINK* the memory is OC'd as well.
Now, if I buy DDR 1600 memory, will that make it OC too fast? Or will that give me more room to breathe on the OC?
2) Are there other advantages to buying a faster set of memory? i.e. is DDR3 1600 or DDR3 1866 better for my system? Will there be any noticeable improvement?
3) Can I mix and match speeds? ie 3x DDR3 1333 with 3x DDR3 1600? It seems a shame to waste the 6GB I have in there, but I would like to get at least 12GB total.
4) How much do the CAS/Timings matter? Do they need to match?
5) I assume I should dial back my OC when installing new memory and go through the process again to test stability... Correct?
The questions:
