[Q]swiFTP Server problem
Ky1e.YC
Member
Guys, having some swiFTP server problem here, thought some can give a little help.
After setting up username, password, I started server. By using Filezilla, i successfully logged in, but when I tried to change the folder, i got 550 error of ftp, saying "failed to retrieve file listing", as you will see below
anyone knows why? please help, thank you.
Froyo Simply Stunning 4.0 is Here! [6/10/2010] - Page 25 - Droid Forum - Verizon Droid & the Motorola Droid Forum
Try the fix here in #245.
"Open Swiftp, and click on setup. Scroll down to where it says "stay within folder(e.g. /sdcard)" Change the /sdcard to just /. Then it works again. But when you open the server, you see "all" the files on your [phone]. Just click on the sdcard folder, and you have access again."
unbelievable, it works as your suggested. Thank you so much.
