I am using the QR code reader to get bitcoin addresses. I don't want to email this information. I hit "content copied" but where does the information go to? How can I put the info onto a text file.
I presume it's text information and it's going to the clipboard. You probably need to obtain a text editor from Play, and then you can just paste what you copied into a text file.
Just "paste", not "paste from clipboard"; all editors have a paste function, surely? In many cases a long press in the text area will pop up a "paste" option but many also have an option in the menu.
Cut/copy/paste all use the clipboard, so if your QE reader has copied something then your editor should be able to paste it. No need to even think about the clipboard itself
