markdoc
Android Expert
I believe that a Soft Reset is the equivalent of a battery pull when the battery isn't removable. I looked that up and found that pushing both the Power and Volume Up buttons did a soft reset. Accepting that, then shouldn't a soft reset empty the list of apps you get when you press the "Recent Apps" button. My problem is that it didn't work. Pressing both buttons restarted the phone, but didn't clear out the Recent Apps. Therefore, something is wrong. Either I didn't do a Soft Reset or a Soft Reset doesn't empty the recent apps. I would really appreciate finding out my mistake.
Thanks in advance,
Thanks in advance,
