Help Question about wifi and 4g
bizcax
I notice when I am at home at the top of my phone screen it shows 4G and my wifi at the same time, I want to know if it is using my data up. My carrier is AT&T
Thanks
Easy to check which is actually used. When apparently connected to WiFi, go to:
Settings > Wireless & networks > Data usage
Make a note of your present usage.
Download a large file or do some surfing, anything that will use a significant amount of data.
Go back to Data usage and check your usage again. If no change, then you were using WiFi. WiFi does not count in Data usage stats. If Data usage increased, then of course you were not using WiFi.
The phone should be switching between WiFi and mobile data automatically, with WiFi taking preference over mobile data. If not it could be the SIM card, APN settings or even the phone. I'd try contacting AT&T for heo next.
You could also try to disable smart network switch (under the wifi settings) and see if this makes one icon to disappear. Just remember to turn it back on if you want to use the feature ;)
Regards,
Eric.
