Question: adding SSD to system
trackball
I just ordered a new laptop so I want to take the SSD out of my current laptop and add it to my desktop as a boot drive. My question is regarding the OS operation. The SSD has Win7 32bit on it (old laptop), and I want to put Win7 64 I have on my desktop onto the SSD. So would I just wipe the SSD, make it the priority boot drive, and add Win7 64? Would it conflict with Win7 on the existing disk or make it so I can't run the applications?
It just so happens I have an extra copy of Win7 64bit OEM because I forgot to check if my laptop was 32 or 64, turns out its the former so I had to get the full version (the one with both disks). Would using that make it easier, or is it unnecessary?
Thanks for any help.
Make sure you have backed up any personal data from that SSD. Just install the ssd into your desktop, power up, throw in the W7 DVD and do a clean format/install. Enjoy the speed :)
Thanks. Yeah I can't wait to try it out on the desktop. My laptop only ran SATA 1.5Gb/s so Im looking forward to seeing what it can really do.
Putting in a ssd after using spinner drives is like giving your pc a new brain. Everything you do is quicker, snappy..dang fast. I have 3 ssds now and hate to think of going back to spinner drives. That said i do have one 1tb spinner drive for disk scraching from programs and general storage. newer spinner drive has reads speeds of 60ishmb/sec while my raid ssds have 449mb/sec read speeds.
Neat little trick to help extend life of the SSD: In addition to things like TRIM, moving hibernation and pagefiles onto spinners, etc. is to move oft use folders, like 1) Special folders (My Documents, etc.) onto the Spinners as well as 2) your Profile folder(s). This is easily accomplished when you're first installing the OS, by way of a little used feature of Win7 called Audit Mode.
Read about it here: Customize Windows in Audit Mode
When you get to the screen where it asks for your Username, do this: Hold CTRL + SHIFT + F3 and it will automatically take you into audit mode with a reboot. Then, you'll get a nice dialog (after you get the "Windows is preparing your computer for first time use" animated screen) that asks what you want to do - change the first drop down to "Enter system Audit mode" and the second dropdown to "Quit" - DO NOT SELECT GENERALIZE!! MAKE SURE IT REMAINS UNCHECKED!! - and then sysprep will create a throwaway admin account for you to use for all sorts of purposes, including installing apps, customizing settings, etc. (Note: since it is an OEM disc, you may have to use the third option to get into Audit mode, not 100% sure - and that OEM disc may not even work, considering it is an OEM version, and probably designed specifically for that original laptop. However, you said you bought it, so....
Next, get Profile Relocator from bootblock: Software by Joseph Cox - extract and run.
How to use:
PURPOSE
Profile Relocator is a step-based application that allows the re-locating of the Windows Users profile directory. Once re-located, any created profiles will appear in the new location in their entirety. The advantage to doing this allows profiles to be stored in a location that doesn't reside on the system drive, ensuring that profile data isn't compromised as a result of re-installation or system failure.
Profile Relocator has been designed to work with Windows XP, Vista, and 7.
USAGE
The application contains the required information on how it works, but below is a brief recap on what you should do. Please note that if the "re-installing Windows" step doesn't apply to you, you can just create the new account from your current account. Unfortunately this means you will not be able to create the new account using your current account's name.
If you're just about to re-install Windows, you should create an account when prompted by Windows during the Windows installation phase using a temporary name. Do not use the name you would like your permanent account to have. For example, use an account name of Test.
Once you've been logged into your temporary account (or main account if you did not re-install Windows), do not install anything except for Profile Relocator. Run PR, read and agree to the the disclaimer in the first step, then select the location you would like all future-created Windows profiles to be located in and click Start.
Once the relocation process has finished, click Finish.
Restart your PC and log back into your temporary account and create your new profile using the User Accounts control panel applet, using the original account name that you wanted. Check the profile destination you entered in PR above and you should see the newly created account in that location.
Log out of your current temporary account and then into the newly created account. Once you have ensured the account is working as intended (no errors being reported by Windows upon login), feel free to delete the temporary account (eg. Temp) that you just logged out of as it is no longer required.
Profile Relocator does not support the location change of existing profiles as is much more risky due to the required number of steps and their complexity.
Since Audit mode creates a throw away Admin account, after (and every time) reboot you get the same dialog as before, with 2 drop down boxes and the generalize button. When you are complete with making all of the changes, leave the first dropdown on "Enter System Out of Box Experience" and the second on "Reboot".
Et voil
I already did the blog lol - a week or two ago. Also sent the software developer an email on how to use Audit Mode to accomplish it versus the manual 'make a temporary throw away account' to use Profile Relocator.
Ramblings from Knee-Ridge man: Use Audit mode to move default folder locations
I'll make a new post with the steps laid out as above.
Well now I have a bookmark.:cool: Now I just have to buy me some SSDs. Annnnnnnnd incidentally now you're required by law to review my apps on said blog.
OK, I might be making that last part up :D
BlueMuze needs a bugfix I'm updating tonight, but I can email you the full version, still the same email right?
