Can you MANUALLY force Timeriffic to change which profile is being used, even if you are in the middle of a time period in which Timeriffic would normally be using a different profile?
Example: Say you have a "home" profile for home and a "work" profile for work. The "work" profile is set to be active from 8AM to 5PM, Monday through Friday. On a random Tuesday, you go home early at 3:00PM. Can you manually switch from your "work" to "home" profile in Timeriffic, or will the app force you to stay in the "work" profile because it is still between 8 and 5, Monday to Friday?
Thanks!
Thanks!
