Question on voicemail...
Fekall
I am looking for an app that would be able to forward my saved voicemails to either my gmail or maybe place it on my sd card. I have tried to send it to my google voice but that didnt work....any suggestions...I have saved this voicemail for over two years now and want to make sure that I have a hard copy of it....help! fek.
I don't know that there will be an app that can do this. I'm assuming that you have a "standard" service provider voicemail system (as opposed to a visual voicemail i.e. the iPhone). I don't think there would be a way for an app to tie into their system, grab the voicemail and forward it to gmail.
What you COULD maybe do is download one of the many call recorder apps, launch it then listen to your voicemail. It will then give you a recording of it you can store/send/etc.
That is Killer...Thanks for the answer on this one...I didn't know that that had that type of capability. you are a saint my friend.
