Question regarding LauncherPro...
dynas7y
I use BetterCut to create a lot of custom shortcuts for programs I use by default such as handcent for SMS, or xScope for internet, etc. I have been using adw.launcher, but I like launcherpro more. The only problem that I am having with launcherpro is that when I long press on the dock to change one of the dock icons, I create a shortcut to handcent with bettercut but the icon then gets placed on the regular home screen. Same thing with other similar shortcuts. Is there any way to have custom bettercut shortcuts stay on the dock? Thanks.
The only way i know of to set custom icons on the dock, is to have the icons in your SD card some were long press on the spot on the dock to change the app, Select custom icon and find the icon you want.
