Samiuddin Ali Khan
I had sent my galaxy s8 to the repair center for Screen burn problem . And they sent me the problems they found and the problems they fixed. The problems found and the problems solved will be down below.
Original Problem:
SCREEN / DISPLAY - LCD / TOUCH PANEL / LED - LCD DISCOLORATION
Problem found:
NO POWER UP - NO POWER UP - NO POWER UP
Solution:
REPLACED LCD - REPLACED COMPONENT
So can anyone explain me what does the no power up means. I am a bit confused.
Original Problem:
Problem found:
Solution:
