I am planning on purchasing a note 2014 edition at the end of the month. And I have a couple of questions I am hoping people might be able to help me with.
1. How is the freehand drawing when using ezPDFreader or repligo reader when annotating PDF files?
2. If you use remote desktop software can you use the S pen to write or draw in apps like MSpaint / photoshop / MS onenote?
3. Does the MS onenote android app support S pen usage?
I belive apps like s notes and lecture notes take the pdf and turn each page into an image file. However with repligo redear that i currently use on my iconia a500 i can freehand draw (very badly with those cheap little stylus thingys) and the notes and drawings are overlaid onto the pdf, and I can then still search the text and even alter the drawn notes on my pc when I transfer the files back.
Thanks for any help you can give me.
