Questions
I just want to know how to post a question and problems which I have with a newly purchased droid tablet. Jim
What is a tag and trackback?
Version:1.0 StartHTML:0000000167 EndHTML:0000002644 StartFragment:0000000517 EndFragment:0000002628
I purchased a 7" e-tablet (Ployer momo9 Tablet PC 7 Inch Android 2.3 New 1.2GHz CPU 8GB 2160P HDMI White - Item #sku10482) and it works very well. The only problem is that I can not read or understand Chinese, so I do not know how to work it well. The company that I purchased it from advised that an English manuel is not necessary as it is easily understood - I have figured out some of the items, by trial and error, but others are a mystery to me.
Is there a place that I can get a manual in English, so that I can understand the functions of the tablet?
I have been able to attach a SD card to the tablet from my Mac, it shows up at the top next to home on the tablet, but I do not know how to open it or be able to transfer the apps or information from the SD to the tablet.
I would like to delete some of the icons (apps) from the e-tablet that are in Chinese so that I am not using up the memory. I have deleted some, but others are in Chinese and I can not figure out where the "delete" or "uninstall" click is, because it is in Chinese.
I put a question in an online site, but it says drag and drop to the trash can. It will not drag and there is no trash can that I can find. I would like to insert icons that I use every day, so I need to delete unused icons.
Anybodys help will be greatly appreciated so that I can use the product.
Thank you,
Jim Boocher
jamesboocher@yahoo.com
This is the tablet:
Item # sku10482
Hello, thanks for joining the Ranks of Androiders -- nice to have you aboard the forum...
There are lots of Help, Hints, Tips & Tricks available for all Android Devices. Make sure to click or tap the Phones or Tablets -Link in my signature - from there just scroll down to your device model.). - You can then join your device's discussion where other users will give you help on getting the most out of your device.
I hope the information on here will be useful to you. Happy Holidays. :)
