Help Questions....
magic99
Hi, I have the Motorola HD.... Not the maxx... I am finding the battery life not that great and hoping to find some tips. I have been doing research but with no luck... Twice my phone died after using for 9 hours. I do have the smart actions set up, I have wifi off, Dimmed the screen brightness
I do use it lots for work, Online and data the most using LTE
My buddy who does the same work as me has the iphone 5 and at the end of 12 hour shift he has 5% battery life...
I went from iphone 4s to Motorola because I heard the iphone has bad battery life and this phone is rated one of the best.....
2nd question, I live in canada and the Jelly Bean upgrade is suppose to be release soon, Should I upgrade?
Thanks
You might have any app running in the back ground that is draining the battery. Try an app like battery mix. I have not used this app but it will tell you what is eating your battery.
