questions
  • Start date Start date
You can't track the SIM, though your network provider could.
There are apps you can install from the Play Store which will let you track your phone, however. Most security apps have this feature. The difference is that if you swapped SIMs with another phone, the security app would track your phone rather than the phone with your SIM in it.
