Quick Easy Way to USB Debugging?
wilberfan1
It gets to be a chore sometimes to drill down to the USB Debugging setting (Settings > Applications > Development > USB Debugging)
Does anyone know if there's a toggle or widget or ... something ... that would make switching back and forth a little less cumbersome?
I've searched a bit in the Android Market, but haven't found anything yet.
It's best just left on at all times. It recommends doing so in my handsets manual and with a lot of custom ROMs it's on by default.
Man, all this time (well, since January--when I got my first Android phone)--I thought Debugging had to be unchecked to mount the sdcard on a computer! (When it's unchecked, and you plug in your USB cable, it prompts you automatically to mount the phone.)
This will save a LOT of time! :D
