Help Quick Help ?
Updated to Jelly Bean now all my apps start auto updating, how do I stop this?
Hello yscty. Just head into the Play Store and tab the main menu on your phone, then tap settings. You'll see that choice in there as a check box.
You can also tap "my apps" and see what choices there are as a list of installed apps/widgets under "downloaded." :)
Thank you, that worked!!!
