Help Quickmemo+ Driving Me Crazy
Rokitman
Hello,
Quickmemo+ has been acting up constantly for several weeks on my LG Stylo. I get popup errors saying, "Unfortunately, Quickmemo+ has stopped." When this happens anything I happen to be doing stops or freezes. Sometimes causing an unexpected reboot. I've tried disabling it and clearing the cache, but nothing works.
It interrupts anything I'm trying to do, shuts off Pandora and just creates a lot of inconvenience and frustration.
Does anybody have a fix for this? I never use this app and would be perfectly happy if I could just uninstall it entirely.
Thanx,
- Dean -
2 options, Unistall or disable, depending if it's a pre installed bloatware
Hello,
Instead of clearing the cache, try 'Force stop' and then clearing data instead. And then try disabling the app again. It should remain disabled, odd that it's apparently still running and popping up those error messages.
Hello,
Thanx,
- Dean -
Check for any updates due for your device and get back with us and let us know. If not we can check other avenues on resolving that issue if there are any available.
