beazpickle
After updating to kitkat my phones boomsound speakers are much quieter thank before the update, anybody else have the same issue?
Can't get into recovery for some reason. Tried to follow the instructions, but volume up and power at the warning screen doesn't do anything but restart the phone.
Quick question on this, is sound only quieter in music player or is it quieter in things like netflix, youtube, pandora etc also?
I may have found a possible fix, turn off fastboot first
1. Power off phone
2. Hold down power and volume down until you're in hboot
3. Go down to the recovery option using volume to choose and power to select
4. You will reach a screen with a warning type symbol
5. Quickly press volume up and power at the same time to get into recovery
6. Go down and select wipe cache partition
7. Reboot phone
Let me know how it works, it seems to have worked for me
Immediately when you see the warning screen hold down the power and volume up for just a second or two, and when you release you should be brought into recovery
Ok but where did you use that method? To get to the boot loader or when you got to the recovery warning screen?I thought it was supposed to be "power button and volume DOWN" - not up. That's what worked for me.
I used the exact method I said, same button combos, once you get to the warning screen hold down power and volume up for a couple seconds the let go, if it doesn't work and you're stuck on the warning screen just keep trying that combo for different lengths of time
Well i said **** it and did the update, speakers were indeed too quiet and the steps outlined by beazpickle did fix it (props man). But like rothe i gotta wonder why this happened and why clearing the cache would fix it. Hope this isnt something i gotta continue to do.
I dunno man i just followed the steps posted above. I bought my phone from radio shack and yep im on virgin mobile.
And yet you got to recovery no problem then?? So then what did you see after the warning screen??
