Yes, that expresses it better than I did earlier. It's more about the continuity - smoothness - of the connection than the bandwidth, assuming the bandwidth is adequate. An apparently solid connection with lots of bandwidth can often go "choppy" when lots of people are using it, leading to exactly the symptoms described by the OP. I guess consistent (and low) ping times are a better metric than download speed in this case.
