Razor SIM card to droid bionic
  • Start date Start date
A
Android Question
Guest
My razor broke and I want to go back to the droid bionic but the SIM card is smaller. Is there a solution for this
Go to Verizon and they should give you a correctly sized SIM card for your phone and activate it for you. So long as it is a corporate Verizon store, it should be free of charge. Some of the premium retailers charge for them so be careful.
Alternatively, you can use some thin cardboard to create a frame to hold your Micro SIM so that the gold contact is in the right place. So long as the contact is held, it will work.
