RCA Tablet Forum Begin
Hi androidcustom.:)
I moved this to the Suggestion Box where admin could see it. Could you give a little more information about the tablets you have roms for (model number, name, etc.) in case it is somethig they would like to create forums for.
Model NumberRCT6378W2
Operating SystemAndroid 4.2
ChipDual Core
Chipset Model NumberDual Core ARM Cortex-A9, 1.2GHz
Resolution800x480
Screen Features7" multi-touch
RAM1GB
RAM TypeDDR3
Capacity8GB
CameraYes
Camera SpecificationsFront facing 0.3M pixel webcam
Battery Life4.5 Hours
Battery Life DetailsWatching movie (WiFi off): 4 hrs., Reading eBook (WiFi off): 4.5 hrs., Browsing Web: 3.5 hrs.
Connectivity/AudioMicroSD card slot, Micro USB jack, Headphone jack, DC In jack, Microphones, Speaker
Here is a link to their website- http://rcatablets.com/tablets/rct6378w2
I believe the stock is jelly bean, i have the 6 files in the rom i just dont know how to make it one file? Can i upload them here? Or is it easy as zipping it up and naming it rom,then just upload that. if someone could make atleast a cwm for it, that would be awesome.
This is the only thread and this thread has the rom. Maybe you can post this thread or should i just post in the new one? thanks i appreciate it
Hi! im new in this forum, hello and good things for all, (my english is very bad ) i have problems with my tablet rca, when i turn on the tablet is like new like factory reset, and my internal memory is 0 0b (total space) i need the rom for this tablet and the rca page dont have anything, someone have the rom or other solution to fix it? thanks :)
I have the RCT6077W2 RCA tablet, does anyone here have the ROM for it? I tried to use this files and it doesn't work.
There are rom files posted in the rca forum but its for the 6378w2 model
I have been stuck with my RCT6378W2 Tablet and have seen many of your posts, including one where you uploaded your .img files. I do not know how to use these files. My tablet cannot boot, and USB debugging is not enabled. To my knowledge, I cannot enable them without booting the tablet. Neither have I been successful with ADB or fastboot as I can't seem to get the right usb driver for this tablet (thanks RCA!). It seems that my only options are to update via sd card, but I have not had any success. Do you have any ideas?
Most of our members speak English only, and you are more likely to get support posting in English. Plus, that's the site rules. We also have a rule that prohibits correcting grammar or spelling, so there will be no flak for broken english using a site like Google Translate (https://translate.google.com).
Your post via Google Translate:
support for editing !! :( Battery and wifi does not work !! :( supports the RCT6378W2
Good luck.:)
