RDS FM Radio app for android car radio
cle74
Hi, I have an Ownice 7" Android 6 car radio.
The build in radio app does not display the RDS radio station name. They cannot test this in China, because they don't transmit RDS radio.
I use the device offline, so I don't have any use for internet radio apps. Should be for normal FM reception, with Radio Data System decoder.
Does an app like this exist? And can it be used in landscape position?
I hope someone has an solution for this!
Gr
Cle
You're right, the FM RDS (Radio Data System) isn't used in China, so some Chinese device manufacturers might not bother having that feature. Basically because RDS never supported Chinese. As RDS depends on specific hardware, just installing an app won't work. Same with DAB digital radio, that's not used in China either.
