re my ott box
re my ott box 4x 4 mxq box
  • to my question
    Votes: 0 0.0%
  • to my question
    Votes: 0 0.0%
  • issy86@hotmail.com
    Votes: 0 0.0%
  • Total voters
    0
guggie86
I want to know how to factory re set it to start from scratch and if I do what all comes back on my mxq box and how do I reinstall stuff?
Impossible to answer. Try asking the people who sold you the box.
Ok the problem I have is I bought it off of a friend.Could you help me figure out then how to get my google play store and you tu be and kodi to work. google tells me connection error to retry and then when I try to go on google I get the security certificate thing and it won't let me go to google. Oh also my kodi is not working. as you see I need major help I have looked on line but I keep getting android help for phone where my issue is the tv android box. Will you be able to help me ???? Thank you for responding.
Google Play services not working and how to fix, is pretty much the same if it's on a TV box, phone or a tablet. One thing with TV boxes though, they'll usually not keep the correct date and time if you power off or reboot them, and an incorrect date or time will prevent Google Play from connecting. If you got date and time set to automatically sync, then the TV box should correct itself in a few minutes, provided it has an Internet connection. And if you have it as manual, then you'll need to do this yourself every time you turn the box on.
hi Where do I find the area to change time and date to make it stay on all the time please. will that fix me being able to go to you tube and connect ?
You should find it in the settings under Date and Time, and then check the Automatic Date and Time option. I don't know your box and how it might have been skinned and modified over stock Android, but settings often has an icon that looks like a gear wheel. If necessary post some screen-shots, so we have a better idea of what you've actually got there.
my box is ott tv mxq android 4.4.2 v2 20160953 kernel 310.33 if that is any help too you. I look to see if I can find the date and time on it . and on the box it says 4xcpu 4x gpu . Thank you for your help I need alot of it this is new to me and I am learning along the way.
hello news up date I got my google play store up and running just wanted to thank you for your help thank you very very much. Dont go to far lol might be needing it again. Thank you Isssy.:):):):):):):)
